breadboard layout
Chillum
Joined Nov 13, 2014
546
I've got "wave (2).asc" and I've got "wave (2)_VeeCAD_v2.pdf" and I'm using VeeCAD for CAD (veecad.com/downloads.html -- free version available, full version got some features, most notably skew components/wire vs just horizontal/vertical)
so remove the .txt on the "wave (2)_VeeCAD_v2.per.txt" if you wanna boot it in VeeCAD,
otherwise
ANY help please
Chillum
Joined Nov 13, 2014
546
huh!? it's a theremin designed to produce a fart sound, I'm building it for my niece, she's 6, hours of farting fun! On my side I've got 555 ICs in the .per .pdf and .asc file NE555, what do you mean by missing IC?
LDC3
Joined Apr 27, 2013
924
Since I didn't want to load the program, I only looked at the pdf file. The breadboard layout doesn't list the IC.
Chillum
Joined Nov 13, 2014
546
OK, sorry I didn't label the IC, but it's labelled in the LTspice .asc and really why do you need that information, we modelled the circuit in LTspice, it works, I only need a breadboard layout that works, because I tried 3 times on v1, (didn't think to version it) and once on v2 and I can't get the .asc file to be the same as the breadboard layout, so really I only need help placing the components on a breadboard circuit that works, help is straight up ?"this wire should go there on not here"? The circuit is sound, only porting it to the breadboard isn't.
Chillum
Joined Nov 13, 2014
546
OK, I thought it was a theremin, it might not be, that's beside the point. This circuit is simulated to do what it should: fart no problem with the design, I can't draw a breadboard layout that works, I'm almost physically tired from trying, desperate would be the word
32,833
Could you post a schematic -- i.e., a screen shot of the schematic as opposed to the design file for a particular simulator package?
How do you know that it works based on simulation? How do you know the waveform displayed sounds like a fart? Did you get the waveform data into a sound file that you could play? If so, how did you do that (I'm curious, though writing a program to translate it wouldn't be too tough).
What is the highest frequency component in any of your signals?
JoeJester
Joined Apr 26, 2005
4,390
Here is what I could determine from you pdf breadboard pictorial diagram .... I'll wait on your screenshot to see how close I came. The software is pebble, if anyone is interested.
JoeJester
Joined Apr 26, 2005
4,390
yep, as I suspected, the pictorial needs work.
I highly doubt there are too many humans that can fart for an infinite number of seconds.
