Breadboard connections
atferrari
Joined Jan 6, 2004
5,012
This is the idea.
If the pots have not common points in the schematic you should twist the wires of one of them to be inserted in separate tracks in the board.
Please consider this a temporary assembly. It would not sustain rough/prolonged usage.
ZNastyMadman666
Joined Oct 30, 2017
3
This is the pot im wanting to use its for volume control on an amplifier circuit.
Do i Cross it over the middle of the breadboard? the dip i guess it would be...
34,810
Solder short lengths of solid 22AWG or 24AWG hookup wire to the legs of the pots.
Now you can connect the wires to your breadboard where ever you wish.
Yes, you will straddle the center groove of the solderless breadboard.
