Breadboard amplifier for 20Watt 8Ohm Speaker
SamR
Joined Mar 19, 2019
5,542
You just might try modeling it in LTSpice first to see what happens? When I breadboard an amp (yeah I know) I like to use small multiturn pots to "tweak" with to try and optimize the waveform on the scope. YMMV Then you can protoboard the results.
dendad
Joined Feb 20, 2016
4,641
I would imaging it will work.
get yourself a copy of the data sheet and see how their application example compares.
Keep the leads short and have the bypass caps as close to the IC as you can.
Audioguru again
Joined Oct 21, 2019
6,826
The schematic you copied will not work because its pin numbers are wrong. It says 20W into a 2 ohm speaker but 2 ohms will seriously overload it, look at its datasheet.
The datasheet does not mention your 8 ohm speaker, it says 20W at high distortion into a 4 ohm speaker when the supply is 14.4V. It might produce 12W at high distortion into 8 ohms.
If you build it on a breadboard then its pins will not fit and how will you cool it? A heatsink also will not fit.
Buy is soon because of 3 versions that Digikey had they say that 2 versions are obsolete and they have no stock. They still have some "R" version in stock but the datasheet does not say what is R (something is reversed?).
ChrisTsall
Joined May 16, 2018
41
Thanks for your reply ! I will keep that in mind !
ChrisTsall
Joined May 16, 2018
41
LTSpice sounds good, I will give it a try, thank you !
Audioguru again
Joined Oct 21, 2019
6,826
I doubt that LTspice can simulate the antique TDA2005 amplifier IC properly, because an accurate model is probably not available.
Instead, simply build it as shown on its datasheet.
bassbindevil
Joined Jan 23, 2014
924
If you're simulating and building an amp for a school assignment, something with discrete transistors might be a better choice. For example, John Linsley-Hood's 10 watt class-A amplifier, which has just 4 transistors per channel in its simplest form. (But class-A means it uses a lot of power and will need a massive power supply and heat sinks).
https://sound-au.com/tcaas/index-1.htm
Or Reg Williamson's amplifier which has an extravagant 6 transistors.
https://www.diyaudio.com/forums/solid-state/187928-picking-ss-williamson-amp-worth-moding.html
