Rolf Zetterberg
- Joined Sep 20, 2008
- 14
MrChips-yes the schematic is correct,but the line between -N1 and V26 emitter should have an earth connection.Without that earth connection it won't work at all(the emitter of the relay transistor is supposed to draw current through an opamp input?-impossible!)To make the schematic more clear and easier to understand,my suggestion how it could be redrawn is shown in the added partial schematic.This way the voltage and current circuits are separated from the relay circuits.
GRNDPNR-sometimes it's impossible to find the exact schematic,and you'll have to do with something close.This is as close as at least I can get since it shows the single supply version.I've followed threads all over the world on power supplies,and I've learned that variations are numerous.Some already have a 10-turn pot(which I personally hate),different pot values and different transistors are often seen.Someone suggested that these are built by different factories that "use what they have".I'm beginning to think he's right.
If someone turns up with a schematic for the dual version,then it will be perfect.
