Bootstrapping DGD05473 from less than 3.3V
busywork
Joined Dec 13, 2023
6
I wonder if it's possible to start up a DGD05473 from 2.7-3.3V until a higher voltage is available in the system. The datasheet says it will lockout if Vcc is below 3.3V. Is there some trick to work around the lockout or am I out of luck?
28,371
Since I have no clue as to what a DGD05473 actually is, what I can tell you is that the short answer is NO! Various circuits have minimum voltages and below that minimum voltage nothing happens, at least nothing useful.
busywork
Joined Dec 13, 2023
6
Yes, I've added a charge pump to boost the voltage above the undervoltage lockout threshold for the startup period. The simulations seem to run fine now. I wish they would lower the threshold to 3V or below (a discharged 3.7V lithium-ion battery).
28,371
There are valid reasons for having a low-voltage lockout, and the one I see as most obvious is the probability of unwanted random actions of the circuit at lower voltages.
