Boost Converter: Power Losses
declan2693
Joined Feb 2, 2018
37
I am trying to figure out the total losses of boost converter.
So my input is 2.9V and 100mA so that (2.9*100mA) = 0.29 Watts
My output is 5V and with 50 ohm resistor, 25/50 = 0.5W.
What am I missing as obviously there should be power losses not the other way around.
artmaster547
Joined Jan 6, 2016
409
hmm this is weird does your converter deliver current to your load? Is there any way you could measure this the output power should definitely be equal or mostly likely less than the input
declan2693
Joined Feb 2, 2018
37
As you can see from the image of the circuit, the amp meter reading from the load is -0.375ma to +0.080ma but the curcuit does work as intended.
I think boost converter IC does increase the current at certain output check the datasheet how much current it draws
kubeek
Joined Sep 20, 2005
5,796
The current is not continuous, therefore you cannot use some simple average or whatever to calculate the input power. You need to mulitply current times voltage for each point in time and then average that, there should be some way to do that in your simulator.
declan2693
Joined Feb 2, 2018
37
That worked thanks
