Hi All
I am looking at creating a cascaded boost converter (Power 300W) (two boost converters), the first of which takes in 12V and outputs 50V @ 6A and the second takes in the 50V and outputs 120V @ 2.5A. I was thinking of using the following controller to do this from TI: LM5022. I wanted to enquire firstly if this is a good idea, if not has anyone got any suggestions?
I also wanted to enquire about inductor and capacitor choices I have followed the worked example and seem to be getting very unusual current values for an inductor I'm getting a peak current of near 100A which seems really unusual to me when comparing this with an online calculator from coil craft I get a much lower peak current around 25/26A, can anyone suggest which value I should trust, (I copied the switching frequency from the example of 500kHz). I also wanted to enquire what approach I should take with regards to selecting capacitors anyone have any suggestions for this? Any help would be greatly appreciated.
Kind Regards
Art
Kind Regards
Art
