MisterBill2
- Joined Jan 23, 2018
- 28,491
At least once, in the past, I solved that problem with a single module that delivered both positive and negative outputs. Regulated, in fact.
Dead in the water as you've laid it out. You have two options:So really then, what I am doing is a 'dead duck' with no future ??
I'm cheap Most of my projects for my own use are powered by "wall warts" from the thrift store.There are dual output power modules available
OK, no way to beat the cheap used wall warts on price ! !I'm cheap Most of my projects for my own use are powered by "wall warts" from the thrift store.
That one offered on Amazon seems mighty expensive. For my needs, this may do the job, even thou its not isolated and to over spec'd.beware of advertisement that cannot be backed up. for example here is an "isolated" boost converter. probably it works nicely...
I fear you have missed the point about being isolated – isolation is required if you're trying to use 2 converter modules from one supply.For my needs, this may do the job, even thou its not isolated and to over spec'd.
Just for information.as already stated several times, you can do that IF the converter is isolated.
but... XL6009 is not isolated: VIN- and VOUT- are already connected internally.
so any time you connect any other power rail to it, you are creating short circuit.
in your case, U26 already has internally shorted IN- and OUT- (2 and 3).
since IN- is tied to "Earth", connecting U26 pin 4 to "Earth" is that short circuit.
