Bode Plots & High Pass, Low Pass, Band Stop and Pass Frequencies
libnitz
Joined Jan 29, 2016
17
I just need some confirmation on 3 questions
1. I was asked to calculate the poles and zeros. I believe
zeros: none
poles: 2 (or p1,2) = -1
2. I was also asked to calculate the slope of the magnitude response was w -> 0
Here is my sketched graph
From my pic, it shows that as w -> 0, H(s) -> 0.
3. What type of filter response does this network exhibit.
I believe it will be a Low Pass because as
s->0, H(s) -> 1 and as s-> infinity, H(s) -> 0?
Does this reasoning make it a low pass filter, high pass, band stop or band pass?
Any help is appreciated
shteii01
Joined Feb 19, 2010
4,644
3.
Yes.
As w increases, s=jw will also increase. s is in the denominator so as s increases, the denominator also increases, so as s becomes bigger, \(\frac{1}{s^2}\) will become smaller and smaller and smaller. So near 0 rad/s (or Hz) you will have some useful response, but as you move further away (toward infinity), the response will sharply drop.
libnitz
Joined Jan 29, 2016
17
3.
Yes.
Thanks! I used the same reasoning as you wrote, however I was not too sure I got it right.
Could you also double check my calculations on this problem also?
MOD NOTE: You already have an active thread on this other problem.
http://forum.allaboutcircuits.com/t...-need-help-double-checking-my-answers.121138/
Please -- one thread per problem (and, ideally, one problem per thread).
