Blown resistor identification
stvmcmlln
Joined Jan 28, 2023
5
Can you take it out and see if the other side is ok so we can read it, at a guess it could be 47ohms?
Hi Dave,
The resistor is scorched all the way around so none of the bands are readable unfortunately.
Thanks for your help.
Perhaps I should just try a 47ohm resistor?
stv
BobTPH
Joined Jun 5, 2013
11,588
Don’t do that! We now know the voltage and current output if the power supply. If yoy can tell us the battery voltage, we can compute the resistor.
Dodgydave
Joined Jun 22, 2012
11,395
Hi Dave,
stv
We need to know what voltage the battery is, the charger says 14V battery and outputs 17.4V, so it's possibly dropping 3V ...so 47 ohms will give you a current of 63mA.
You need to check the diodes to see if they are not blown too
BobTPH
Joined Jun 5, 2013
11,588
I am going to guess the battery is NiCad given the simplistic charger. And it is a 0.1C trickle charger, i.e. it takes about 12H for a full charge.
dl324
Joined Mar 30, 2015
18,432
It's a 5% tolerance resistor, so the significant digits can only be 43 or 47. If you could make out the 3rd band, that would tell you if it's 4x, 4.x, 0.04x.
What is the capacity of the battery being charged? It must be a NiCd, probably being charged at 0.1C because there's no charged detection.
dl324
Joined Mar 30, 2015
18,432
Thanks for the responses! Here’s a pic of the battery. It’s an aftermarket battery.
That's not a very good charger for a 14.4V NiCd battery. Fully charged, it would be 16.8V and the adapter is only outputting 17.4V. You'll lose 1.4V in the bridge rectifier, so there's not much voltage left to charge the battery.
Did the charger burn up because you tried to charge a bad battery, or one with a low voltage?
I'd try a 47 ohm 3W resistor. Charging a dead battery would make it dissipate 6W. It would be okay down to around 5V.
stvmcmlln
Joined Jan 28, 2023
5
Thank you! I’ll try that.
