BJT transistor analysis
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hi everyone...
I need to calculate the Ic for the attached circuit, using Thevenin method!
β=167.1
Vcc = 20V
R1 = 160kΩ
R2 = 40kΩ
Re = 1kΩ
I'm calculating Vth = (40/(40+160))*20 = 4V
Then Rth = (160*40)/(160+40)=3.2kΩ
Then using input net (base net) I'm calculating Ib as:
Ib = (Vth - Vbe)/(Rth + Re(β+1)) = (4-0.7)/(3.5k+1k*(167.1+1))=19.26μA
Then using Ic = β*Ib = 167.1*19.26μA = 3.22mA but the correct result is 2.75mA... Can't figure out where am I going wrong!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I have another problem... This time is with LTSpice.
I'm trying to simulate the attached circuit but it is taking for ever to finish the simulation.. Why?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, if I want to write the 2 nets (input and output), can I write then like this:
Net 1 - Input net
Vcc = R1(Ic+Ib) + Vbe + Vγ
Net 2 - Output net
Vcc = R1(Ic + Ib) + Vce + Vγ
Are these 2 equations correct?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Is this post #4 circuit.? and what is vy.?
Yes it's about post #4. Vγ is the LED voltage. I think it's called forward voltage, right? Let's consider the following values:
R1 = 2.1kΩ
Vcc = 12V
hFE = 119
We are asked to find current at R1.
So, I'm doing:
Ib = (12-0.7-2.5)/(2.1k*(1+119)) = 34.92μA
Vce = 12-2.5-2.1k*(34.92μa+34.92μA*119)=0.721V
Ic = 119*34.92μA = 4.155mA
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Looks close enough to me.
Have you checked it using LTSpice.?
Not yet checked with LTSpice...
The problem is that the answer should be 4mA.
This is a question that our tutor posts in our school's site (quizz) and that we must answer to it within a given deadline. A friend of me helped me and we have calculated a value of 4mA sharp and the quizz "told me" the 4mA values was correct.
But current across R1 is Ib + Ic. So it should be greater than 4.155mA, but the quizz said that 4mA was correct!
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I can't find them in the calculator... probably the screen "run out" of memory to store the calculations history and deleted the oldest calcs I made. And I can't remember the values of R1, Vγ and hFE.
Every time we attempt to answer the quizz, these values changes!
Anyway, the most important was to know that the net equations I wrote were correct! The rest is math that the calculator does!
