This equation is OK.I thought that Vcc-Ic.Rc= Vou
Wrong, not so fast. You forgot about the base current.Vb=Vcc.700/(700+R2)
Looks good .Vcc-Ic.Rc-Vce-Ie.990=0
If the equation Vcc-Ic.Rc=Vout is correct then how the output voltage changes for different values of R2?This equation is OK.
https://forum.allaboutcircuits.com/threads/transistor-base.81886/#post-585781
Looks good .
By changing R2 you change the Vb voltage. Hence the Ib and Vbe will also change. Or we can say that by changing R2 value you change Vth voltage and Rth resistance.If the equation Vcc-Ic.Rc=Vout is correct then how the output voltage changes for different values of R2?
Yes Vb and Ib are changing so that Vbe is also changing but there is no equation for Vout and Vbe or others. Vout is related with Vcc and Ic. Ohh i understand now. If Ib changes Ic also changes. My mistake! Thank you so much!! By the way i cant say Vcc=700.I1+I2.R2 right? Vcc is only coming from collector or not?By changing R2 you change the Vb voltage. Hence the Ib and Vbe will also change. Or we can say the by changing R2 value you change Vth voltage and Rth resistance.
Right.Vcc=700.I1+I2.R2 right?
