What's the difference between hfe and hf'e? I never did see an explanation for that in the other thread.Hi for the question in the attached image below, would
Ve/Vs = [hfe*Re]/[Rb + hie + (hf'e*Re)], with hf'e being the value I found for Vc/Vs?
Ok but would Vc/Vb stay as (-hfe*Rc)/{Rb+hie + (Re*hfe)} or would this also be Re*(hfe + 1)?I would rather have:
\(\text{\frac{V_e}{V_s}=\frac{R_E(1+h_{fe})}{R_B + h_{ie} + R_E(1+h_{fe})}}\)
where hfe is the value per the original problem statement.
Not entirely, I think it's because it's the resistance Re + the resistance of the emitter Re affected by the hfe of the junction?Do you know why we use (hfe+1) ??
We use hfe+1 because the emitter current is equal toNot entirely, I think it's because it's the resistance Re + the resistance of the emitter Re affected by the hfe of the junction?
So to clarify my initial question is yes it would be (Re*hfe+1)/{Rb+hie+(Re*hfe+1)}?We use hfe+1 because the emitter current is equal to
Ie = Ib + Ic = Ib + Ib*hfe = (hfe + 1)*Ib
And this is why Re resistor is seen at the base as (Hfe +1)*Re
Check your parenthesesSo to clarify my initial question is yes it would be (Re*hfe+1)/{Rb+hie+(Re*hfe+1)}?![]()
Sorry just spotted it (Rc*hfe)Check your parentheses
The correct one is Ve/Vb = (Re*(hfe+1))/{Rb+hie+(Re*(hfe+1))Ve/Vb = (Re*hfe+1)/{Rb+hie+(Re*hfe+1)
It's supposed to be Vc/Vs, it's just a typo.But you in post 9 show equation for the voltage gain
But now Vc/Vb = ?
If there were a capacitor across Re that grounded/shorted Re, would Ve/Vs still = \(\text{\frac{V_e}{V_s}=\frac{R_E(1+h_{fe})}{R_B + h_{ie} + R_E(1+h_{fe})}}\) ?t_n_k is right.
Vc/Vs= (hfe*Rc)/{Rb + hie +(Re*1+hfe)}
Although technically wouldn't Vc/Vs = Vc/Vb since R1, and R2 are ignored?
Ahh ok, I see. ThanksOK, now every thinks looks good except one small detail.
The voltage gain Vc/Vs is negative because transistor in common emitter configuration have 180 degree phase shift.
When the base current increases the collector current also increases.
As you can see when input voltage is increasing ( base current also) the Vce voltage decrease. So we have 180 degrees out of phase (negative gain).
No ,try to use small signal analysis and you will know.If there were a capacitor across Re that grounded/shorted Re, would Ve/Vs still = \(\text{\frac{V_e}{V_s}=\frac{R_E(1+h_{fe})}{R_B + h_{ie} + R_E(1+h_{fe})}}\) ?
Would there be no gain since Re is grounded meaning Ve/Vs would = Vs?No ,try to use small signal analysis and you will know.
