CD4067 is CMOS not TTL.CD4067 is a pretty old 5 Volts TTL integrated IC that decode 4 to 16 lines. You should find it using google.
Alberto
Are CMOS transistors available?
Who cares. Small error on print, gate 11 out should go to gate in nor's on 10. also ,all1's inputs are paralled,as with 2's 4's & 8's.If a few pins are strapped together the 4007 gives three CMOS transistors, but how can they be converted into and gates?
