Binary Relevance by Matlab
katkoutexpress
Joined Apr 9, 2013
6
Hello every body, actually i wanna make a binary relevance using a such algorithm, by matlab .. Please, can anyone help me to find the appropriate code for th binary relevance by Matlab??? Thank u :))
33,109
That's a pretty open ended request, don't you think?
The notion of binary relevance, as I understand it, it related to grading the relevance of materials in an information retrieval system. So there would be many aspects of implementing "a binary relevance" and you've given no hint as to what aspect you are refering to.
katkoutexpress
Joined Apr 9, 2013
6
look ! what i meant by binary relevance , is that it could be a method for multi-label classification problems :
"Traditional algorithms are unable to handle a set of multi-label instances,
since these algorithms were designed to predict a single label. A simpler solution is
to transform the original dataset into a set of instances in which each set contains all
attributes, and only one of the labels to be predicted, the method known as Binary
Relevance (BR)." I hope u understand now what i meant :)))
