Bike motor
shortbus
Joined Sep 30, 2009
10,049
I first thought of a gas engine but it increases the weight more than a motor? Hence, dropped it.
I have one of those gas motors, not for a bike but just the motor alone. They aren't all that heavy, I used mine for a different purpose so just bought the motor. The whole system that you will need the electric motor, batteries and the drive system, verses the gas motor system I'm betting would weigh pretty much the same amount. Plus if you batteries would go flat away from home verses running out of gas, I'll bet it is easier to find some gasoline than it would be to find someone with the right charger.
shortbus
Joined Sep 30, 2009
10,049
Thanks. Was it a 66 cc motor?
No it was I think(was a couple of years ago) it was 79cc. But they are all pretty much the same motor except for the stroke. If you look on Ebay there are quite a few to chose from. I built a gas powered winch for out in the woods. Had an electric winch that was given to me it's electric motor was burned out so I adapted the 2stroke motor to it. I was cutting fire wood so always had 2 stroke gas for the saws.
28,502
Back about 1967 I helped put together a pulsjet engine to drive a bike. One loud tone when it was working, and the back half of the engine glowed orange. It ran on gasoline mixed with kerosene for added impulse energy. The installation was simple, It just bolted to the rear carrier. The problem was the heat would melt the rear tire if you could ever get it stopped. Not much throttle control, it was always full power or off.
beatsal
Joined Jan 21, 2018
425
Thanks. My problem is that I need the exercise of pedaling so would only need motor boost on going up a slope say 10% of the time only. If I use an engine with tank etc. I won't be able to pedal on even ground as the added weight will slow or stop me. I thought of using a very small engine as in aero models - won't work. Then someone suggested a 10 - 20 cc engine but can't find them so am stuck
28,502
Once again, I suggest having a lower gear ratio available. At some point you should be able to pedal up most hills. With my best low gear selection the thing that stops me is the rear wheel slipping because of not enough traction. And if I put more weight on the back wheel then the front one lifts and I can not steer.
Alec_t
Joined Sep 17, 2013
15,160
On level ground the added weight makes very little difference to pedalling effort. The only difference I noticed when riding my power-assisted bike was balance/stability, because the centre of gravity was higher.
28,502
With a low enough gear you should be able to pedal up a 30% grade with no problem. Not fast, except that you would be pedaling a lot faster. On my mountain bike the biggest sprocket in back is smaller than the small front sprocket. Strictly a steep hill type of gear. But at that point you do need to have at least 5 rear sprockets and 3 on the crank end. So the setup may take a bit of effort. But still far simpler than adding a motor or engine. And it is totaly "street legal", while any engine may be challenged.
35,278
It seems to me that you need to be knowledgeable and handy in a number of areas:
1) mechanical engineering - calculating power, torque, gear ratio
2) electrical power engineering - battery, motor, controller design
3) bicycle mechanics - free wheel sprockets, chains and gears
4) metal work, welding equipment and skills
If you are up to snuff with all of these and are a DIY person then go for it. Otherwise you may want to save your pennies towards an ebike conversion kit or a ready-built ebike.
beatsal
Joined Jan 21, 2018
425
Thanks. Think a kit would be best, but would like a friction rear-wheel drive kit. Don't see any!
35,278
Darn. I just gave away one of my ebikes to a reseller a few weeks ago.
The only friction drives I can find are sold from China. They are pricey. C$400 and up.
Here is a side mount drive.
Seller location is confusing. It says item is located in Ontario, Canada. Yet seller is in China.
Caveat emptor - I cannot vouch or make any recommendations on this or any product. You have to judge your own ability to install this product. It does look complex.
C$118.85
https://www.ebay.ca/itm/24V-250W-El...805827?hash=item2ad9638a83:g:-vsAAOSwhU5fD~ts
YaeGoo 24V 250W Electric Bicycle Motor Kit, Easy to DIY E-Bike Economic E-Bike Conversion Kit Electric Bike Side Mounted Motor Design
Buyers need to know:
This kit is not suitable for any bike, contact us before you purchase it.
please see the pictures carefully, or contact us before you purchase the kit. you can send the pictures of your rear wheel to us,
both left side and right side, we can give you some suggestions.
All the buyers should have experience to install it. If not, please do not buy it.
This kit includes:
1). 1pcs DC 250w 24v motor
2). 1pcs motor controller
3). 1pcs chain
4). 1pcs freewheel
5). 1pcs freewheel adapter
6). 1pcs mounting plate with bolts
7). 1pcs throttle handle & brake lever
8). 1pcs headlight
9). 1pcs switch & key
10).1pcs 18cm axis
Note:
This kit suitable for 22"-28" bicycle.
This kit without battery, battery charger and battery box.
beatsal
Joined Jan 21, 2018
425
C$118.85
This kit includes:
3). 1pcs chain
4). 1pcs freewheel
8). 1pcs headlight
10).1pcs 18cm axis
Note:
This looks good. It says may not suit all bikes, contact us. I clicked contact us but no luck.
