Here's a SCR library :
Thanks for that. Now all I need to do is work out what to do with itHere's a SCR library :
Many thanks for taking the time to do that. Above and beyond.I ran a sim of the right-hand half of the circuit in LTspice and agree with your results: Q3 collector never gets high enough for T3 to get triggered.
I will re-create that circuit later tonight and try to understand it. (is it okay to ask you dumb questions about it?)I would probably have used a circuit such as below to terminate the discharge at a set battery voltage :-
Here, TL431 provides a reference voltage settable with a trimpot.
At power-up, R1C1 keep the Trig input of the 555 low for a brief period to trigger the 555, pin 3 of the 555 then goes high and the relay coil is energised. As the supply voltage drops, the input to the internal comparator inside the 555, which is about 2/3 the supply voltage, drops below the reference voltage so pin 3 goes low and de-energises the coil. Even if the supply voltage bounces back up, the 555 is not re-triggered.
Just open the lib file with any plain text editor, e.g. Notepad or similar.Do you have an "uncompiled" -- is that the right term? -- version? I'd like to see what is inside.
Sorry. My editor saw the .lib extension and threw it on the screen in hex, so I thought it must be a compiled format.Just open the lib file with any plain text editor, e.g. Notepad or similar.
I'm happy to answer questions about the circuit I posted.
| Thread starter | Similar threads | Forum | Replies | Date |
| Y | VNA calibration linked causality questions | Wireless & RF Design | 1 | |
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
Current draw questions | General Electronics Chat | 37 | |
| T | Solder composition questions | General Electronics Chat | 9 | |
| C | basic questions about soldering. Beginner | Technical Repair | 47 |
