Beginner in electronics, simple question about a mechanical relay circuit
gerases
Joined Oct 29, 2012
186
Hello, I'm trying to build a circuit below where the LED will toggle every second. I'm using this relay: https://www.farnell.com/datasheets/1918250.pdf. -- model v23105-a5401-a201. So I am at a point where I don't even have the LED+resistor in the circuit. I just want the relay to turn-on-off every second. I have a 1000uF capacitor. What happens is that with just the relay and the power supply connected, the relay thrashes, which I expect. When I connect the capacitor, things slow down but I want to slow them down to once per second. I don't have a higher value capacitor, so I was trying to put a resistor (R2) in. Above about 60 Ohm, the relay stops working completely though. My power supply is 5V but I've also tried 9V.
Here's a portion of the datasheet:
Does that mean the coil must have 5V of voltage minimum to work? If so, it would explain why putting a resistor in makes it stop working -- since there will be a voltage drop on the resistor?
For simplicity, according to my calculations, with a 1000uF capacitor I would need a 200 Ohm resistor to get the time constant of 0.2 second. Since it takes 5 such constants to charge a capacitor fully, I will get my 1-second cycles. I might be off, but it's close. The problem however is that this relay stops working with much smaller value resistors.
Any ideas are welcome!
Thanks!!
LowQCab
Joined Nov 6, 2012
5,102
Remove the Resistor, it only confuses the problem.
Your Time-Constant calculations should use only
the Capacitance, and the DC-Resistance of the Relay-Coil.
That's the whole thing.
Do You expect a "Pulse", or a "50-50" Duty-Cycle ?
sghioto
Joined Dec 31, 2017
8,751
The relay you chose has a low coil resistance of only 62 ohms. Any resistor in series with it will drop the voltage. The specs indicate that relay requires a minimum of 3.5 volts to operate. With a 200 ohm resistor you would need a 15 volt supply.
gerases
Joined Oct 29, 2012
186
Try 3 2200uF (6600uF) capacitors in parallel, without R2, and with 5v supply.
Yeah, biggest caps I have are 1000nF and only two of those. I think I'll get me this: https://www.amazon.com/Electronics-Salon-9999uF-Step-1uF-Programmable-Capacitor/dp/B00UT03HO2/ref=sr_1_8?crid=300NW9MRAYDZG&keywords=capacitance+substitution+box&qid=1642703686&sprefix=capacitance%20substitution%20box,aps,65&sr=8-8
Is there a more suitable relay for this that would turn on with 1 or 2V?
LowQCab
Joined Nov 6, 2012
5,102
If You would state exactly what it is that You are trying to accomplish,
there may be far superior methods to achieve that end.
Are You trying to learn about Electronics, or, do You just want a flashing LED ?
35,193
I'm trying to strictly learn electronics at this point. No particular project in mind. Just playing with well-known circuits.
In my books that is not a well known circuit. I suppose it would work but I have never seen anyone do this before.
It is not exactly electronics.:confused:
35,193
Tridon is large after-market automotive parts manufacturer. They used a 555-timer IC for their intermittent windshield wiper controller and flashers.
gerases
Joined Oct 29, 2012
186
Thanks guys, I do know there are more elegant ways to achieve this, but this is where I'm starting after a long break and I'm just having fun. Blinking the light is not the goal really. It's just playing with the breadboard and this is simple enough for me to understand.
28,344
This is a circuit to demonstrate RC time constant, but it seems that the explanation has been rather inadequate, And the relay really has a much lower resistance than would be good for the explanation.
When power is first applied the capacitor starts charging through the 100 ohm resistor, but the current is also flowing through the relay coil. If the voltage ever reaches a value high enough to engage the relay, then the charge will stop and the relay will discharge through the coil resistance until the relay releases, at which time the cycle will start to repeat.
35,193
If you wish to learn about RC time constant, charging and discharging, then read up about 555-timer circuits and how they work. There are a lot of sites with good visuals that demonstrate this.
