BEAM solar engine oscillator
Dronehead19
Joined Sep 21, 2020
Screen-shot-2011-03-21-at-5.13.34-PM.pngScreenshot_20200906-121427.pngHere's a rather simple problem I've been hung up on for a while.
For anyone unfamiliar with the first circuit, it basically builds up a charge in an array of capacitors, then, when the FLED is triggered, the capacitors discharge through the motor in a short pulse. My intention is to replace the motor with a simple two transistor oscillator to instead make a short "beep" when the circuit is triggered.
I've tried simply substituting the second circuit for the motor with no luck. It must serve a crucial role that, as a novice, I'm unable to figure out.
I'm sure there's a solution somewhere. Anyone's help is greatly appreciated!
Bernard
Joined Aug 7, 2008
5,784
What end result are you looking for? Maybe a solar operated beeper? Might use parts of BEAM, solar panel & cap for power supply, FLED & 2N3904 as a pulsing switch. On drawing, substitute your beeping circuit for R3 & LED. On bread board I used, R1 = 1k, R2 = 2.7k, FLED = white @ about 2 F / sec. piezo beeper, 2N3904 for 2N2222, & power 3 NiMH AAs. FlasheScan.jpgr flashes & beeper beeps.
sghioto
Joined Dec 31, 2017
8,749
The problem is the component values shown in the schematic. Can't recall exactly which book it's from but that looks like page from a Forrest Mims notebook.
Change R2 to 330K and R1 to 4.7K. You can raise or lower the pitch by changing the value of C1. This worked on my breadboard.
A simpler solution is to use a DC beeper.
SG
