The OP never specified what relay he was using. I just used a convenient relay component to show a more conventionally drawn schematic.Odd thing is that 6v version is 25mA/240ohm not as stated by TS.
I've used 5V relays that would pick up at about 3V.Mind you, 80% of rated volts isnt uncommon, so still might be marginal on 5v.
I agree with that. 4 mA of base current and the transistor has a Vce of 1.2 volts.Your schematic drawing style is very strange, and the simulator is crap. Are the meter widgets ideal?
You're operating a 6V relay at 5V. What's the pick-up voltage?
it seemed your transistor is on through out. Bipolar transistors turns on for very little base currents (mA, uA) where your Vbe > about 0.6v. To switch it off, the base voltage would need to be really low, closer to GND.yes. I replaced the transistor but at 5mA base current ( which means the transistor is on ) it don't work properly.
