BC337 transistor switch
Catriona82
Joined Feb 15, 2017
47
Hi everyone, just need some quick advice.
I want to use the BC337 transistor as a switch to control an arduino lilypad twinkle via an output of a lilypad MP3 player.
With 4 LEDs being driven by the twinkle the max Ic is around 100mA.
What I'm not sure about is what gain value I use to calculate the base resistor. The datasheet says min is 100 on the data table but one of the graphs shows a curve when Ic/Ib = 10.
Which one do I use? :confused:
AlbertHall
Joined Jun 4, 2014
12,663
If you are using the transistor as a switch assume a gain of ten to make sure the transistor is saturated so you get the minimum voltage across the 'switch'. This also keeps the power loss in the transistor to a minimum.
hp1729
Joined Nov 23, 2015
2,304
Gain will change with collector current and which BC337 you have, At 100 mA gain will be 100 minimum on most types.BC337-16 is different than BC337-25 or -40.
dl324
Joined Mar 30, 2015
18,524
100 is for operation in active mode. When operating in saturation mode, many designers use 10. That's what you're seeing in the graph you mention. Some use 20, but I was taught to use 10.
No one will use the stated beta value of 100 for saturation mode operation. Note that that value is specified for a Vce significantly higher than the saturation voltage. In addition to being dependent on collector current, beta also has a dependency on collector emitter voltage.
38,952
For minimum saturation voltage, when using a BJT as a switch, a current gain of 10 is typically used.
If you want to minimize the base current, and a possibly slightly higher saturation is acceptable, then you could use a gain of 20 to calculate the required base resistor.
But I would never use a gain value higher than 20 for good design practice.
ian field
Joined Oct 27, 2012
6,536
A logic level MOSFET in the same TO92 package wouldn't need any base resistor.
