Battery socket connection
Kittu20
Joined Oct 12, 2022
511
Hello Everyone,
I have a battery socket, but unfortunately, there's no indication of the model number or any polarity signs on it. As a result, I'm unsure which terminal is positive and which is negative. Could anyone provide guidance or information on identifying the positive and negative terminals?
Thank you for your help!
Lo_volt
Joined Apr 3, 2014
373
The center contact is negative. The contact that is the clip on the side is positive.
A lot of coin cell part numbers are derived from the cell size. A CR2032 cell is 20mm dia. and 3.2mm thick. Measure the inside diameter of the socket and the thickness below the retaining clip to determine the size of the intended battery.
