Battery replacement calculation help needed
oriddlero
Joined May 2, 2019
8
I should know this, but Ii'm confused and need help.
Load is currently 9VDC 2A for 3-second bursts (electric trashcan door opening).
Currently runs off of 6x C-cell batteries. (1.5v * 6000mah)
If I run the trachcan off of an 18V 12AH Lithium Ion battery pack using a voltage reduction board to get 9v 2A output what would the expected capacity be?
It's making my head hurt. Anyone feel like mathing this?
Wolframore
Joined Jan 21, 2019
2,619
depends on the battery pack... battery packs are designed with current limit. Lithium ion will be able to supply higher current (again depends on protection circuitry)... I recommend a DC-DC converter if you're going this path (one rated for at least your current requirement).
oriddlero
Joined May 2, 2019
8
Yes, I already have a DC DC converter rated at the current needed and its running fine. The battery pack is designed for high current (its from a Milwaukee power tool)
Just was looking for rough calculations on how long the new setup will run vs. the old setup.
Wolframore
Joined Jan 21, 2019
2,619
sounds like it would be fine... no idea what your converter is capable of... your 18V 12000 mAH running at about 80-95% efficiency should get you to almost 4X the running time... just a quick estimate but there are a lot of variables including how this is wired.... etc.
oriddlero
Joined May 2, 2019
8
Thank you for the estimate. Any chance you could take me thought the math?
Wolframore
Joined Jan 21, 2019
2,619
Let's assume 100% efficiency, then if you convert 18V 12AH to 9V it is now able to give you 24AH...
P = I x V
12 x 18 or about 216 watt hours
to convert to 9V (at 100% efficiency)
216 = i x 9 or 219 / 9 = 24
24 AH at 9V
you still have to de-rate this on the loss from conversion but I have no idea how efficient your converter is and how it's wired (like what does it do while waiting... could be losses there)
using C cells you said it was 6000 mAH
24000/6000 = 4 more capacity (again 100% efficient)
KeithWalker
Joined Jul 10, 2017
3,628
Your power requirement is 9 volts at 2 amps which is 9 x 2 = 18 watts.
I will assume that you are using a buck converter to get the 9 volts from the battery pack.
If it is 80% efficient you will have an effective battery capacity of (18V x 0.8) x 12 AH = 172.8 watt hours
The maximum time will be 172.8 watt hours / 18 watts = 9.6 hours.
Audioguru
Joined Dec 20, 2007
11,248
If you over-discharge a lithium battery then it is ruined. 18V is 5 cells averaging 3.6V each. Then a fully charged battery is 5 x 4.2V= 21V. You must add a low voltage disconnect circuit set to about 75% of its fully charged voltage. About 15.7V.
oriddlero
Joined May 2, 2019
8
I'm fairly certain major tool manufactures (This is a Milwaukee M18 power tool battery) have built-in over discharge protection and balancing already incorporated.
oriddlero
Joined May 2, 2019
8
Thank you for this, its exactly what i needed. Could one than also assume: based on 9 hours = 540 minutes = 32,400 seconds. The cycle of the trash can opening/closing (load) around 8 seconds = is 32,400/8 = Approximately 4,050 open/close cycles? IF the trash can opens ~20 times per day = 202.5 days until recharge?
Wolframore
Joined Jan 21, 2019
2,619
we are only guessing at this point. I would knock that figure down by at least 10-20%. I have no clue what your circuit does while it’s waiting to open your trash can. Could be uA could be mA. You have added circuitry into this which is unknown.
oriddlero
Joined May 2, 2019
8
Absolutely understood. The unit has an IR sensor that is constantly powered looking for motion-to trigger the open/close action. The buck converters has a power LED that is on 24/7 (ill probably de-solder this off the pcb as it's not needed), + the efficiency loss loss due to the step down.
BobTPH
Joined Jun 5, 2013
11,678
When you start extrapolating to years, you have to take self discharge onto account. They lose about 2-3 % per month according to Wikipedia.
Bob
KeithWalker
Joined Jul 10, 2017
3,628
I did not check your figures but your reasoning is correct.
Be aware that Lithium Ion batteries do self discharge. They lose about 3% over the first 24 hours and then 1% to 2% per month so you will have to take that into account.
Is the battery disconnected from the power supply board between openings? If not, then you will also have to take into account the small amount of current the supply will take when idling.
