Battery level indicator
Tomas4174
Joined Oct 28, 2016
10
Great morning,
today I got three battery level indicators with 4 pins (IN, GND, GND, VCC). When I was about to buy it, it was like "Yeah, one is + and one -". Now I contacted the seller and they sent me a circuit (see the picture). Now can you explain it so I can understand it (for ex. + goes to VCC or something like that)
I believe in you guys, please help me out
Tomas4174
Joined Oct 28, 2016
10
Thank you for answering but an you more specify it?
Talk to me like to a beginner. I am at the very start. Really just like that: plus connect to VCC and so on
ericgibbs
Joined Jan 29, 2010
21,649
hi,
OK, can you follow this diagram.?
I am assuming you want to measure 0v to +12vDC and you have a +12v for the module.
What is the voltage you want to measure and what power supplies do you have, batteries etc.?
E
Tomas4174
Joined Oct 28, 2016
10
That is way better for me, thank you. I just do not know the difference between the input and the supply
For the specification: I will use a 5V rechargeable battery. It used to be a powerbank.
ericgibbs
Joined Jan 29, 2010
21,649
hi T,
The KA2284 can be powered by a voltage from 3.5v to 16v, this is the Supply voltage to the KA,
The input voltage is the voltage you want to measure.
The KA draws only 15mA from the Supply voltage.
E
Tomas4174
Joined Oct 28, 2016
10
So if I understood that right: I should connect the battery to IN and GND. Am I right? If so, what to do with VCC and the 2nd GND?
Btw. I can't even imagine how to thank you... I would destroy I way before I was able to know how...
Tomas4174
Joined Oct 28, 2016
10
Ok guys, I think we are almost at the very end... The indicator works, only it lights up all the diodes regardless on the battery level.
Tomas4174
Joined Oct 28, 2016
10
I can't take pictures right now, but you can see it in the picture "A03.jpg" Eric made.
There is the VCC and GND to the supply (used a 9V battery) and a INPUT with GND (there I used a old celphone battery, because the battery I need to use -5V- has not arrived yet.)
When I was making the picture, I knew that it's not gonna help much.
