Battery float charger question
Gdrumm
Joined Aug 29, 2008
684
Should a battery float charger put out more than 12 volts, when it is not under a load?
I'm getting 19+ volts AC from the wall wart, but downstream I'm only 10+ volts at the Pos. Neg alligator clips.
It's a Harbor Freight item, and I probably got it on sale for cheap.
Perhaps it would work on a low battery, but not raise above the 10 volts when hooked up to my multimeter.
Does that make sense?
Thanks,
Gary
Wendy
Joined Mar 24, 2008
23,810
I am not an expert, but my understanding is 13.7V is nominal. You can sense the state of change on a SLA battery by the voltage on it, which is what a float charger uses to determine how much current to feed in.
The Battery University
Gdrumm
Joined Aug 29, 2008
684
I will try the resistive load, but now there is another problem.
I found a swolen capacitor, and replaced it.
As soon as I plugged it all back in, I smelled smoke.
I thought I had left my soldering iron on a shop towel.
It took a couple of seconds to realize the replacement cap was smoking..
Are there any general things to look for, when that happens?
All of the resistors look good.
Thanks,
Gary
35,114
Most likely you installed the capacitor backwards.
What was the capacitance and voltage of the original capacitor?
Gdrumm
Joined Aug 29, 2008
684
I thought of that after I posted.
It is / was a 25v 100mf.
Here is a drawing of two capacitor symbols
The top one is the one I'm used to seeing.
The bottom one is what is on this board.
I thought I was paying attention when I took the old one out, but perhaps not.
Have you seen this bottom symbol for a cap before, and do I have it labeled correctly?
There are no + - on the board.
Thanks
Gdrumm
Joined Aug 29, 2008
684
I found it,
On the board, Pos is the white side, Neg is the black side.
