battery discharge problem
Mussharraf Hossen Shoikot
Joined Jul 28, 2017
24
the problem is that i use solar to charge the 12 volt lead-acid battery. when i connect it to inverter and my 70 watt load with battery, the inverter repeatedly deactivates and activates so i have to charge the load while the load is shutdown. explain to me why this is happening.
bertus
Joined Apr 5, 2008
23,031
What are the details of the solar panel?
What are the details of the battery?
What are the details of the inverter?
What are you using as load?
How is everything connected?
Bertus
Joined Jul 28, 2017
24
Bertus
disregard, i think i found the problem, it is the battery having not enough charge in the beginning. i use the battery at night after charging it in daytime. the battery is connected to inverter only and inverter is connected to a load of the watt range in OP. any way to mark the post as solved?
