Battery cut-off when discharging
nickbell
Joined Mar 19, 2014
1
First let me say I have little or no electronics background.
I am hoping to build a battery discharger, and I want this unt to cut off at 3.3v. (a little background here, I race radio controlled cars using 3.7v lipo batteries)
I somewhat understand and can read these circuits from my engineering background, however I have no earthly idea what I need to change to achieve this cutoff.
I'll be starting at 3.8 volts with approx 30amp load
thanks for the help
Nick
magnet18
Joined Dec 22, 2010
1,227
you just want it to shut down entirely? or do something like send out a warning?
Racing RC cars, is weight a factor?
the simplest route (in my opinion), is get an arduino or other uC(microcontroller), measure the voltage, and shut it down with a relay (or use a transistor somewhere in the control circuitry to inhibit the thing)
just my opinion, I'm a fan of arduinos though
Alec_t
Joined Sep 17, 2013
15,167
Is this discharger an in-car or out-of-car thing? Do you have a power supply other than the Lipo available for the discharger?
inwo
Joined Nov 7, 2013
2,419
I didn't understand this to be an "on board" device.:confused:
"I am hoping to build a battery discharger,"
Seems more like a battery tester.
magnet18
Joined Dec 22, 2010
1,227
i took it as an onboard device that shuts the car down when the batteries hit a certain point, we should probably wait for op input rather than running away with this though
burger2227
Joined Feb 3, 2014
194
Lithium batteries can be ruined if discharged too far. I'd assume he wanted something to avoid that.
He's probably wondering where his thread went...
