Battery Circuit Design
wayneh
Joined Sep 9, 2010
18,136
Ummm... Have you even started? You're given quite a bit of information about the individual components and how they are to be connected. Once you lay out what you're given and still have questions, we can help step you through. It helps no one if we do your homework for you.
ayractgc
Joined Feb 3, 2018
52
I don't have an idea how i connect these.But i know that 4s3p configuration with 26 modules has 385V so they will be in series but for other components like fuses and contactors i dont know how much and how should ı connect them.I know inverter should be out of the batteries as two pole. I dont know where should ı connect ac charge connector and also dc
wayneh
Joined Sep 9, 2010
18,136
Perhaps you missed a lecture or a reading assignment? Do you understand what all the listed subsystems are meant to accomplish? Start laying out what you DO understand and see if you can tick off the requirements. Once you've got the layout, you can go forward and answer the other questions.
