have power pro PCB4L&6L 661-11101401-006, 240/12 battery charger, 2700mA: no op.
Odd component under board, 2 wire, heat shrink wrapt, rectangle with rear cylinder, in series with +ve op. might have v small sub board or be regulator? charger has 2 LEDS [red and clear] no fuse. red LED works when powered, other?
some poor joints on board. SUSPECT bad disconnect blew it, or screw jammed beside board inside it, but not in contact when found.
edit#1
prob an scr charging limiter, but i don't know what's in them. assume op goes off when battery reaches 13.x v?
edit#1
