Battery capacity tester
Status
Not open for further replies.
DonMuncy
Joined Dec 18, 2011
20
I previously posted and received help on a battery capacity tester on this forum, and now find it has been moved to power electronics .
Crutschow, If you don't mind checking there, I would appreciate your help.
ScottWang
Joined Aug 23, 2012
7,509
Crutschow will receive the moving information about the new forum, so please don't worry, if you wish to notice someone to see the post on the forum then you could using as @DonMuncy and then the member will receive an alert and go to check where was the alert came from.
This thread will be closed since it is no needed.
Status
