I have a CyberPower AVR900 Battery Backup UPS that is having issues recharging the batteries.
What I am asking is ......
1). How does one go about diagnosing the problem with circuit board in hand like this? I've heard of using InfraRed but I don't have access to that.
2). Is there a "most likely" culprit in situations like this?
Notice the 8 pin micro chip in the lower left corner of the photo below just above the capacitor. It looks like the board has been toasted on the right side of this chip next to the diode. Is that suspect? it's a Viper22A Low Power OFF-Line SMPS Primary Switcher.
Nothing else on the board looks suspect, visually. No bulging capacitors, no other burn marks etc.
Also, on the back of the board where the chip is soldered looks odd. Most of the pins are soldered together? I wonder if the excess heat flowed the solder to them or if they are supposed to be that way?
