Basic FET amp gain problems
CalTN
Joined Oct 15, 2023
I know the following equation.
Av=gm*Rd
Rs are my load resistors.
Is the equation really as simple as gm * Rs?
Example from (a): (3000uS)(4700ohms)
My textbook and lecture notes offer no help. I'm an hour in and am more confused.
I am only solving for Av or gain.
Ian0
Joined Aug 7, 2020
13,253
Av=gm*Rd
Well . . . it would be, if you had a common-source amplifier, but what you have drawn is a common-drain amplifier, for which the gain will be slightly less than 1, and will vary by only a small amount if you change gm, Rs or both.
WBahn
Joined Mar 31, 2012
33,123
Av=gm*Rd
You may "know" that equation, but it's apparent you don't know where it comes from, what it means, or when it is and is not applicable.
As a result, instead of "knowing" that it applies to a specific circuit topology in which there is a drain resistor (hence Rd), you choose to simply through whatever resistance happens to be lying around at whatever equation comes to mind.
Not the way to approach engineering.
So take a step back and LEARN how to analyze these circuits, not just regurgitating equations to throw at them.
