Base tesistance in NPN transistor.
ADGALE
Joined Nov 24, 2022
12
Hi!. I've got a question. Why the base resistor changes in related to the C-E resistance in order to achive the saturation stage?. I mean, the transistor doesn,t have a fix value to achieve this stage?. Why this happens?.
LvW
Joined Jun 13, 2013
2,035
Yes, i mean the resistor that you use in the base of the transistor.
"in the base" ? Either you mean (a) the differential resistance rbe BETWEEN the base node and the emitter node or (b) an EXTERNAL resistor between a voltage source and the input at the base.
DickCappels
Joined Aug 21, 2008
10,661
Or are you asking, in the case of a grounded emitter transistor inverter, why base drive current needs to increase in order to keep the transistor saturated when the collector load decreases?
dl324
Joined Mar 30, 2015
18,454
This is in Homework Help. Post the complete text of the problem and any associated schematic.
DickCappels
Joined Aug 21, 2008
10,661
The TS is from Spain, this is the text of post #7
El mensaje en la publicación #7 es importante.
"Esto está en Ayuda con la tarea. Publique el texto completo del problema y cualquier esquema asociado".
38,762
No.
A BJT transistor is considered technically to be a voltage operated device but the collector-emitter current is also proportional to the base-emitter current once a base-emitter voltage of about 0.6V is reached.
Look at the current-gain value (beta or hfe) value in the transistors data sheet.
For good saturation, a base current of 1/10 the collector current is usually recommended.
As to why, that just the way a bjt works.
