Base Resistor Value for PNP Transistor on Solar Light Circuit
kmarques
Joined Feb 4, 2018
25
Here's the updated schematic. Does anyone know what the PNP base resistor value should be? I'm coming up with 3.2K, but I'm not quite sure if that is correct.
ElectricSpidey
Joined Dec 2, 2017
3,358
The base resistor must go to ground (negative)
And you were told that the transistor is redundant.
I would think the base resistor would need to be about 220 ohms.
EDIT:
Incorrect schematic removed.
kmarques
Joined Feb 4, 2018
25
How is it redundant? Here is the scenario... Battery gets charged all day. Night comes and you decide to flip the switch and light up the cockpit. Well, after a few drinks and some great conversation you get tired and head into the cabin to sleep... completely forgetting to flip the light switch off. Thankfully, when the sun rises the next morning the PNP transitor has cuttoff the LEDs and the solar panel continues to charge the battery.
ElectricSpidey
Joined Dec 2, 2017
3,358
The way you have it configured the LEDs will light whether the battery is charging or not.
The PNP will be on because it is connected to the battery.
kmarques
Joined Feb 4, 2018
25
If the PNP base is receiving the proper amount of power from the solar panel, how will the collector make a connection to the emitter?
kmarques
Joined Feb 4, 2018
25
Yes, but a PNP needs a negative bias at the base to conduct from emitter to collector.
When it’s sunny, the output of the solar cell is high at the transistors base, which opens the transistor and switches off the LEDs.
When it gets dark, the solar cells voltage drops to zero, the current flows out the transistors base and through the solar cell to ground, this closes the transistor letting the current flow through the LEDs.
Alec_t
Joined Sep 17, 2013
15,156
Your total LED current is 150mA. When a transistor is used as a switch, the rule of thumb is to assume a current gain of 10, to ensure the transistor switches on hard. Therefore the required base current will be 15mA, hence the base resistor will be (3.7-.7)V/15mA = 200Ω. Use 220Ω (as ES suggested in post #22).
What is the maximum voltage output of the solar cell? There is a risk that it could cause reverse breakdown of the transistor base junction unless the voltage is clamped (with, say, a zener diode from base to ground).
ElectricSpidey
Joined Dec 2, 2017
3,358
Thanks, I completely overlooked that path.
kmarques
Joined Feb 4, 2018
25
On a real sunny day I’ve seen the voltage go up to 6V. Manufacturer states that it is a 5V panel.
BobaMosfet
Joined Jul 1, 2009
2,211
Alec_t, thanks for all the great info. Just out of curiosity, at what voltage would you begin to consider using a zener diode?
You can have zener's work down to close to 1V, but you need to also be aware that zeners tend to require at least 10mA in order to function. Also, are you preventing too much current from flowing into your LEDs? a 1-ohm resistor won't protect them.
I agree, you learn more by doing, but so far, you seem to be letting others kind of build it for you. But, you have what's most important, the desire, and you are asking questions, so keep going. But I *urge* you to get this book:
Understanding Basic Electronics
(Publication No. 159 of the Radio Amateur's Library) 1st Ed.
Author: Larry D. Wolfgang
ISBN-13: 978-0872593985
ISBN-10: 0872593983
It is a very fun text, and will answer literally all the questions you have, with examples and problems. Not only will it give you a means to learn in an organized way, it will give you a valuable reference you can go back to, again and again.
dl324
Joined Mar 30, 2015
18,462
You don't want the base-emitter junction to breakdown. For the transistor you're using, and just about every one I've ever checked, that's 5V.
Even small reverse currents can kill beta.
kmarques
Joined Feb 4, 2018
25
Thanks dl324, the specs clearly state that the base max voltage for transistor 2N4403 is indeed 5V. As suggested, I've added a zener diode (1N4732) to the circuit which has a breakdown voltage of 4.7V. Here's an updated schematic. If anyone sees any issues, please let me know. Thank you all for your help!
Alec_t
Joined Sep 17, 2013
15,156
An alternative to using a zener would be to connect a normal silicon diode in series with the 220Ω resistor. This would have the advantage of not wasting solar cell power in the zener.
