Banggood Scope Kit
debe
Joined Sep 21, 2010
1,419
If you go down the Banggood DIY CRO path. Check these pics, there is a fair bit of noise in the amp. But for the price I built 2 of them & reasonably happy to use them. Just alow for the noise.DIY CRO Mains hold.JPG DIY CRO TEST Hold.JPG
debe
Joined Sep 21, 2010
1,419
Tried all that & suspect its noise in the amp ic. This is with the input switch in Gnd position.DIY CRO.1.JPG COMP Side.JPG TRACK Side.JPG
debe
Joined Sep 21, 2010
1,419
All testing was battery power. Heres the circuit of the power supply part. Pics of wave forms on Q1 collector & TP25. Both Horz 10us & Vert 1mv/div. Bottom pic is TP25. Have also tried disconnecting the neg 5v power feed, an feeding that with a battery. Still the noise was there.DIY CRO Q1&2, probe position.JPG DIY CRO.circuit, PS.jpg DIY CRO Q1-2. Hor 10uS, Vert 1mV..JPG DIY CRO Tp25 V-- Hor 10uS,Ver 1mV.JPG
