You need to keep in mind that an inverting unity gain amp (closed loop gain=-1) has half the bandwidth of a noninverting unity gain amplifier (closed loop gain=+1), due to the fact that the inverting amp has a feedback ratio of Rs/(Rs+Rf), which is 0.5 in this case.Jim Karki's paper is good but rather laborious for a simple task. Normally the closed loop bandwidth is defined as the point at which the gain is down 3dB from "0" frequency gain. Look at the op amp's open loop gain curve on its data sheet (if there is no open loop gain curve you got the wrong op amp) enter the y axis at the closed loop gain and cross over till the curves intersect. At the intersection drop down to the frequency axis and read the 3dB freq i.e. the closed loop BW.
Isolated Gate Drivers Failing When Feedback Loop Is Closed | Power Electronics | 22 |
| Similar threads |
