Hi! I'd be so glad if anyone answers the following question:
Design a two-stage "bandpass" RC filter, in which the first stage is highpass with a breakpoint of 100Hz, and the second stage is lowpass with a breakpoint of 10kHz. Assume the input signal source has an impedance of 100Ω. What is the worst-case output impedance of your filter, and therefore what is the minimum recommended load impedance?
Thank you for all your supports.
