Bandpass filter in IoT
jn2
Joined Jan 3, 2017
18
What is the application of a bandpass filter (f0 = 300 MHz, Q = 50) in the domain of IOT?
Thank you for your help.
Papabravo
Joined Feb 24, 2006
22,116
The purpose of a bandpass filter is to pass signals whose frequency is within the passband of the filter. In this case, the center frequency of the passband is at 300 MHz. If you divide the center frequency of 300 MHz. by the Q factor of 50, you get the bandwidth of the filter, which is 6 MHz. This means the passband of the filter is from 297 to 303 MHz.
jn2
Joined Jan 3, 2017
18
I think you misunderstood my question.
we know that bandpass filters are very used in communication systems (GSM, 3G,...) in the RF and IF sections with a specifique center frequency and Q-factor.
Whereas for 'Internet of things" domains I do not know what they are the requested characteristics of a filter to be used in this domain
Otherwise, how can I link between a bandpass filter used in a telecommunication systems and the Iot domain?.
Papabravo
Joined Feb 24, 2006
22,116
You need to provide some context for a meaningful answer. If the IoT device is the filter, then the link to the filter is over the communications channel whatever that is. If the filter is part of the communications channel then the connection is as described above.
