balance loudspeaker volume
yoamocuy
Joined Oct 7, 2009
84
I've got a group of loud speakers that are used to play radio programs from time to time. Each loudspeaker has a different cable length and as a result the loudest loud speaker is drastically louder than the quietest loudspeaker. Ultimately I need to balance the sound. I was thinking of just attenuating the sound of all the loudspeakers so that they match that of the softest loudspeaker but since these are consuming a large amount of power i dont think i can just put a resistance in series with the cable to drop the volume... I was thinking of an l pad but thought id see if anyone had other suggestions
34,829
How many loudspeakers are connected at the same time?
How far apart are the loudspeakers?
How are the loudspeakers wired together?
Are the loudspeakers the same, i.e., are they identical?
What is the impedance of each loudspeaker?
What amplifier or device is driving the loudspeakers?
The devil is in the details.
Denesius
Joined Feb 5, 2014
124
Also make sure the polarity on all the speakers match that of the amplifier output. For example, if one speaker out of 4 is reversed, to the ear it will sound quite a bit lower volume than the others.
#12
Speakers vary quite a bit in quality. It is much more likely that your speakers are not the same quality as each other compared to the connecting wire causing problems.
djsfantasi
Joined Apr 11, 2010
9,237
Can you answer MrChips questions in post #3? Can you swap the soft speaker with the loudest one, and see if the problem also moves? This will isolate the problem to either the speaker or the wire and amplifier. Make sure polarity is correct so that you don't introduce another problem.
alfacliff
Joined Dec 13, 2013
2,458
the normal way to do this is to use a 70 volt wireing system. each speaker has a 70 volt transformer with taps that allow you to set the power available at that speaker. by stepping up the voltage, you reduce resistave losses in the speaker wire.
