Okay. This is happening in a car.
I have an aftermarket stereo which has a USB port.
I also have a USB hub that requires power.
I've successfully stepped down the voltage from 12v to 5v using a converter.
The converter is wired to the RETAINED POWER wire on the radio harness and grounded on the ground wire of the radio harness (Retained power is hot when the ignition is on and remains hot for 10 minutes after its off OR someone opens the vehicles door while the ignition is off.)
The radio receives its power and ground using the same cables.
The radio ALSO receives CONSTANT POWER from the "BATT" cable which is ALWAYS HOT (Used to keep the time and date.
WHEN THE USB HUB ALONE IS CONNECTED TO THE CONVERTER, IT FUNCTIONS AS IT SHOULD, RECEIVES POWER WHEN IGNITION ON - DIES WHEN IGNITION OFF AFTER OPENING DOOR OR WAITING 10 MINUTES
WHEN THE RADIO ALONE IS CONNECTED TO THE POWER SOURCE IT FUNCTIONS AS IT SHOULD.
WHEN THE RADIO AND USB HUB ARE BOTH CONNECTED TO THE SOURCE THEY FUNCTION AS THEY SHOULD....
UNTIL
YOU CONNECT THE RADIO USB PORT TO THE USB HUB...
When this happens NEITHER DEVICE GOES OFF.
I removed the Inverters ground and both devices remained ON.
I concluded what must be happening is that CONSTANT POWER from the BATT cable is sending current through the radio (intended to keep the clock time) and traveling through the USB cable, into the HUB and back down POWER CABLE of the USB HUB into the RETAINED POWER cable and powering the head unit, making it as if it was never turned off... The issue is... when the radio is SUPPOSED to be off, power is backfeeding down my USB Hubs power cable and into the RETAINED ACCESSORY cable and keeping it on..
If I use a relay, it would have to be wired to the retained power cable to activate when power is triggered, the PROBLEM with this is.. like my radio, it would always receive power because power is flowing the wrong way.and the relay would never disengage.
If I used a diode, I will experience a voltage drop and I must keep it at 5 volts after the transformer...
If I use a MOSET on the USB hubs POWER CABLE, then the power coming up the USB cable from the radio which is received ALWAYS HOT battery power...will still power the USB hub because the MOFSET will short it to a ground when current is going the wrong way so the power will go from my radio, up my USB Cable, Into the USB Hub, OUT my power cable and into the MOFSET ground thus keeping my USB Hub ALWAYS HOT..which will drain my battery...
Are there any ideas or ways to attack this?
UNTIL
