Auto polarity reversal
wachanna
Joined May 26, 2021
12
Good day chaps, im flambustered with curiosity in search of how to automatically reverse polarity every minute. I have in my possession a 1 horse power 12 volt DC motor, which, if i hook up to a conveyor belt, i want to reverse the direction every minute, but, in order to do that, i would need to manually unhook the power cables from my power supply, and reverse the polarity. Living in the current year we do, it seems there just must be a way to use modern day wizardry to switch the polarity every minute automatically by using some sort of circuit, but since i am no pro, nor even had a class about this stuff, i have not a clue as to how to make such a circuit, so pretty please with the kindness of your beautiful hearts, could you please help me figure this out?
drc_567
Joined Dec 29, 2008
1,156
Numerically, converting horsepower to watts, the 12 volt DC motor would require about 65 amps DC (745 watts/12 volts=65 amps) at minimum. So figure on that amp rating, and maybe a little extra, in whatever switching mechanism you decide on.
MaxHeadRoom
Joined Jul 18, 2013
30,741
A circuit using four suitably sized SCR's would do it, but instant reversing a 1HP motor is not a good idea with some pause in between to allow a stop first.
ScottWang
Joined Aug 23, 2012
7,504
If you don't want to use general relay then I'm thinking to use a 555 and set to one minute, and some transistors, some P, N MOSFETs to build a H-bridge driver, each P, N MOSFET in series with a low values resistor, seperated the P, N, P, N MOSFETs, and each MOSFET in parallel with some MOSFETs to increase the current, N type in parallel with N type, P type in parallel with P type.
* it seems too frequently to reverse the polarity for one minute.
Note :
Don't forget to add the heatsink for the MOSFETs.
Ya’akov
Joined Jan 27, 2019
10,263
If you are using the motor at full power this probably isn't emopugh current handling but this is an example of something remade: https://www.amazon.com/Forward-Reverse-Control-Two-way-Timing/dp/B07P9NZ5WN/
You could build your own circuit, but you might want to start with a commercially built timer module and do the switching part. As @MaxHeadRoom mentioned, you are going to have to pause between direction changes to avoid damaging the motor, they don't like suddenly changing direction at all.
LowQCab
Joined Nov 6, 2012
5,101
With a few Modifications this Circuit could do the job.....
It stops the Motor before Reversing direction, and then smoothly ramps-up the Motor Speed.
MaxHeadRoom
Joined Jul 18, 2013
30,741
This is why I asked in #9 if mains power was available,
But in the case of the T.M.'s the SCR is used on the output of the bridge rectifier in order to ramp up the 200vDC, it turns off every time the ripple transits through zero.
wachanna
Joined May 26, 2021
12
https://www.google.com/aclk?sa=L&ai...6rezwAhVeIDQIHZU7ArcQwg96BAgBEBk&dct=1&adurl= I found this. It doesnt have the power requirements for my 1 hp motor but its a clean simple design i could play with. What could be installed to the manual switch side to make it automatically reverse polarity every minute? My first thought is 2 time delay on/off circuits, but i need a circuit i can trust will only have one way on at a time. How can this be accomplished?
Ya’akov
Joined Jan 27, 2019
10,263
A timer and a bistable multivibrator (flipflop), both can be gotten as modules. You would use one timer that pulsed each minute and the flipflop would switch state on each pulse.
