I am looking for a way to hard wire this cheap eBay Bluetooth receiver to my car.
You have to press the middle power button (also pairing button and call answer button) for 3 seconds to power it up. Short pressing the same button during an incoming call answers the call. It has a built in battery so needs to be charged via USB. What I would like to do is have this powered on with the car radio 12v remote wire without having to press the power on manually each and every time I get in the car. I would also like it power off with the car stereo.
Can someone help me with a circuit using transistor to help me achieve this. Bearing in mind, I would still like the call answer feature to also work (same button) which I will wire to a button on the steering wheel remote. A capacitor and resistor across the switch may work but will short out when answering calls. I think this may be able to be achieved with a transistor. I have seen something similar somewhere but here I need it powered on when it sees power from the radio remote whilst still having a fully functioning call answer button and not short out when pressed. Any help appreciated.
![](/proxy.php?image=https%3A%2F%2Fi.stack.imgur.com%2FpWUmG.jpg&hash=572496360c44aaabba7282aab6d4c8a8)
