Auto generated differential equation for a series RLC circuit
micropad
Joined Dec 24, 2011
109
Dear Experts,
I need to verify whether, when designing a series RLC circuit, it is necessary to generate the differential equation based on the circuit design. Is there any software that can automatically generate the differential equation for a series RLC circuit? Does PROTEUS support it
I need to understand how the behavior of the differential equation changes when the components in a series RLC circuit are altered, especially when an additional voltage source is added. How does this transformation affect the equation from a homogeneous to a non-homogeneous form?
Thank you
Papabravo
Joined Feb 24, 2006
22,113
To design a particular series RLC circuit it is not necessary to write the differential equation. It is only necessary to write the solution based on the values of the parameters. Why is this the case you might ask? The answer involves two properties of 2nd order linear differential equations:
  1. Solutions always exist. There is no 2nd order linear differential equation that has no solution.
  2. Solutions are unique. If a 2nd order linear differential equation has a solution, it is unique.
General solutions are written down by finding the roots of the characteristic equation. Particular solutions are found from the general solution and the initial conditions.
micropad
Joined Dec 24, 2011
109
Dear Sir,
Thank you so much for your response. I have recently completed my HND In Electronics and Electrical Engineering , where I studied various mathematical expressions related to electronics math, such as differential equations, Laplace transforms, Fourier series, Taylor series, and Maclaurin series. Additionally, I covered topics like critical damping, over-damping, and under-damping. and lot more
I am eager to apply what I have studied practically, which is why I am looking into this myself. I found information on ChatGPT that LTspice, a software from Analog Devices Corporation, is suitable for this purpose. However, I was unable to locate an auto-generator for differential equations based on my RLC circuit. I am interested in understanding how the differential equation changes when I modify the values in the series RLC circuit and how it transitions between homogeneous and non-homogeneous forms when I introduce an additional voltage source. These are the aspects I want to explore.
It would be greatly appreciated if you could provide some motivational ideas or guidance to help me pursue this independently.
Thank you
Papabravo
Joined Feb 24, 2006
22,113
The following article
RLC circuit - Wikipedia
shows the differential equation in standard form and allows two parameters which are derived from the component values to describe the response of the system. The two parameters are:
\( \omega_0\;=\;\cfrac{1}{\sqrt{LC}} \)
and
\( \alpha\;=\;\cfrac{R}{2L} \)
which will characterize any possible response to arbitrary initial conditions. This will be a good starting point.
28,411
Usually the first step in creating a circuit design is to establish the requirements. Every attempt to create a design with undefined requirements has resulted in an unsatisfactory outcome.
Certainly the Analog Devices company will provide you with accurate advice, while "Chat GPT" will, at best, deliver a bunch of words that might mean something.
