Audio wave form imitator circuit
LikeTheSandwich
Joined Feb 22, 2021
209
Range? Most of those remote cars have a range line of sight of about 50 to 100 feet.
Ron
Fine for my needs.
I believe you got ripped off target has them for $1,24MHz
Did you mean $10, 2.4GHz? I didn't want 2.4GHz, they had some at Walmart too. I'm not concerned with long range and sometimes those cheap toys have trouble pairing with the 2.4GHz band. And especially since 2.4GHz is so much more common now, 27MHz will probably have less risk of interference now-a-days.
Delta Prime
Joined Nov 15, 2019
1,311
Fine for my needs.
Yes that is correct thank you for catching that
Reloadron
Joined Jan 15, 2015
7,934
Fine for my needs.
Then run with it. As long as the range meets your needs.
Ron
