Audio transmission using a 5 mW laser and a solar panel!
Ya’akov
Joined Jan 27, 2019
10,300
Well, the distortion could be from any one or several parts of the system.
I don't have enough information about the components involved, so I have to start by speculating.
The laser diode needs a driver. The driver needs to provide constant current to the diode, and there are a couple of ways it could do this. Depending on the rated input of the diode, it may be a buck or boost converter. It could also be based on opamps but so far as I can tell that's very unlikely.
Those converters convert the input to AC internally to make the change. I don't really know, yet, how that could be interacting but it is a place I would look.
bertus
Joined Apr 5, 2008
23,006
I have loaded the sample2.wav into audacity and normalized it to get a higher amplitude to -1 dB.
I have taken a view waves from the middle of the centre and they show more distortion than the ones @Yaakov showed:
I do not know the difference, as I do not know where @Yaakov did his sample.
Bertus
AnthonyKpS
Joined Apr 12, 2019
16
Let's assume that the scenario you describing is simpler than it looks and I fully understand what you are saying, how can i physically do tests on such small components. The laser diode is enclosed in a metal casing.
Also, I'll be posting a reply with more info about the parts so anyone can have a better overall look
Ya’akov
Joined Jan 27, 2019
10,300
One place I would check is at the input to the diode. If would help to see of the source is distorting, or only the receiver is.
Ya’akov
Joined Jan 27, 2019
10,300
Bertus
@bertus I used the last sample. Your method removes my playback device and is better.
AnthonyKpS
Joined Apr 12, 2019
16
bertus
Joined Apr 5, 2008
23,006
Here I made a screenshot from the last part of the sample2.wav:
It looks like in this sample there is a cross-over distortion.
Bertus
