audio power transformer schematic question
spuddo
Joined May 2, 2013
76
Hi
The attached is a power supply schematic of a Pioneer A-656 amp.
I am wiring it up for 240 volt operation.
Using pins 2 & 5 as the primary connections.
In the schematic it shows pin 4 , connected direct to neutral , with what appears to be a fuse ?
I have not seen this symbol before.
Any thoughts.
Thanks for listening.
My guess would be a transformer fusible link or thermal overload symbol meaning it should always be in the power circuit. I would suspect a move of the wire from 3 to 5 while leaving the other wire at 4 would be the proper way to go. Lots of Japanese equipment had tap provisions for 200VAC 50/60Hz operation on the power transformer that might not be on the English versions of the drawings.
spuddo
Joined May 2, 2013
76
Hi
Any thoughts.
[/QUOT
Thanks for your reply , could not find that symbol (fuse in circle) , but make sense now.
As you say , i should connect neutral to pin 4 and active to pin 5.
Best regards.
