Audio amp power transformer question
spuddo
Joined May 2, 2013
76
Hi ,
With the transformer out of circuit i got these readings:
Primary :
Pin 5 to Pin 4 L = 16 Hs ,
R could not register a reading. ?
Secondary :
Pin 9 to pin 10 L = 17 mHs
R = 100 mOhms
Pin 10 to pin 11 L = 17 mHs
R = 100 mOhms
Pin 9 to pin 11 L = 74 mHs
R = 500 mOhms
This seems to indicate the transformer is OK (famous last words).
When wired up and fired up back in the power supply , these are the readings :
Primary :
Pin 4 to pin 5 240 Volts
Secondary :
Pin 9 to pin 10 0 Volts
Pin 11 to pin 10 0 Volts
No smoke , no fuses blown.
This seems to indicate the transformer is kaput.
Any thoughts.
Thanks for listening.
BobTPH
Joined Jun 5, 2013
11,621
Why do you think the readings are inconsistent? When I calculate the expected voltage for the secondary from the inductances, I get 7.8V,. Not exactly 10, but not way out of whack..
Bob
spuddo
Joined May 2, 2013
76
Bob
Thanks for your reply.
The readings for the output were 0Volts , not 10Volts
spuddo
Joined May 2, 2013
76
There may be an internal fuse in the transformer. You can sometimes get to them by removing the frame.
thanks for your reply.
There is a fuse shown in the schematic , but as i could read 240 Volts and measure 16 Henrys i considered the primary was OK.
BobTPH
Joined Jun 5, 2013
11,621
Inductance is the square of the turns, so the turns ratio is the ratio of the square root of the inductances.
Tr = sqrt(0.017) / sqrt(16)
Vout = Vin * Tr
Bob
sarahMCML
Joined May 11, 2019
703
Hi ,
Primary :
Secondary :
R = 100 mOhms
R = 100 mOhms
R = 500 mOhms
Primary :
Secondary :
Any thoughts.
What do you get between pins 2 and 5? You may be able to ignore the internal fuse and rely on the external one.
BobTPH
Joined Jun 5, 2013
11,621
Not sure how he got inductance reading of an open circuit. Come to think of it 16H for the primary and no resistance reading seems wrong. Perhaps the 16H was just the max reading if whatever he is using to measure it?
Bob
spuddo
Joined May 2, 2013
76
Thanks for your replies , sorry for the delay , i come from a land down under---you go to bed , i get up.
Pin 2 was the original connection for neutral.
In a previous question to this forum i was advised to use pin 4 , made sense , now we have the fuse in circuit.
In the schematic it is a little blurry and looks like pin 2 and pin 4 are connected , that appears to be a draftsman typo and doesn't make sense.
First picture: primary pins 4 & 5 L= 16.9 H secondary pins 9 & 11 R = 910 mOhms.
Second picture: primary pins 4 & 5 R = ? ( no milli's) secondary pins 9 & 11 L = 74 mHs.
Best regards
28,113
Given the symptom, a resistance check of each winding would be the first step. Given the failure mode, reading 240 volts across the primary indicates that the mains connections and power switch are OK, and tells nothing about the transformer.
The clue is in the schematic, where a thermal fuse is shown inside the transformer. These are usually the cause of an open primary circuit. On many occasions this device is accessible from the outside of the transformer, and it can often be seen by looking at the edge of the windings on the mains connection side. I have been able to carefully cut the paper over the device and remove it, or just installing a jumper across the open device, and then closing up the paper covers. It is very important to chech the rest of the system after this fix to see if there is really an overload due to some failed part, or is it just a poor quality thermal fuse. Once the problem is fixed it is important to have an external fuse in the mains feed to avoid a problem if an overload happens again.
Poor quality thermal fuses are much cheaper than having an external fuse, which is the reason that they are so common. The equipment makers do not care at all that the cost of a replacement transformer will prevent repair of the equipment.
It doesn't even have to be a thermal fuse. It just there to prevent people from bypassing stuff. I had a can opener that had a fuse just under the paper. The transformer had a lump that sould not be there, so I peeled some away and there was a small regular fuse.
The fuse in your diagram looks out of place and I have no idea why you looked at inductance first.
I only worked on one amp that had a primary to case short. I didn't see it at first because I use an isolation transformer. It wasn;t repaired for the customer.
I moonlighted for an outfit that did consumer electronics repair. Strange way we became friends. I was in the store and an amp came back and I offered to take a look at it. That was the start of a nice relationship. I did their audio amps that were not simple. I'd picked them up. They would order schematics and parts and I'd fix after work and after class. Win-Win. They now totally switched gears and are doing IT network stuff. They had a strong background in Satellite TV, the large dishes.
One particular AV amp came back to their shop about 3x for the same problem. An amplifier IC went bad. Turns out the turn-on transient exceeded the maximum rating of the IC power. Easy to fix.
Another amp was interesting. A disco owner borrowed a high power 200W amplifier from a relative and it broke. The amp was taken to five shops and they all refused to work on it. I have never seen components that "puddled" on the PCB. i.e. metal film resistors melted. Nonetheless, he wanted it fixed at any cost.
After fixing it, I did add thump suppression. The output connectors were totally shorted.
A good proportion of the repairs were the large amplifier STK modules in Fisher amplifiers.
Another issue that was consistent was the use of 1 to 10uF electrolytic capacitors for coupling.
Very few amps had a DC adjust. All had bias adjust.
They did a lot of VCR repairs and had to quarantine some because of roaches. They found a sandwhich in one VCR.
I worked on an amp full of cat hair because the cat liked to lay on the warm amp.
At work, I did some electronic servicing. Not a lot, but some. Since we had about 8 vacuum gauges, I stocked parts for those.
We had a bunch of DCR series switching Sorenson power supplies, that ended up with the same failures like replace electrolytics. I maintained x-y recorders. They required maintenence, like replacing calibration pots and lubricating the slidewires, replaceing the electrostatic hold downs. I did a lot of modifying stuff, so the problem would not occur again.
I trouble-shot the DEC LSI-11 systems to the module level.
Then there was the high power, high voltage stuff like 0-100kV power supplies for an X-ray diffraction system, a 1000 W tube RF transmitter for an RF sputtering system and the 0-15 kV 1.5A power supply for a CV-8 ebeam evaporator power supply.
At the other end of the spectrum, I built systems to measure femtoamps of currrent.
I built some solenoid drivers.
I spent a lot of time designing I-V converters. My flagship was a 4-terminal +-100 mA FS, with 3 more decade lower ranges at +-10V out that was capable of biasing +-10V. It had suppression of +-50 mA. It was intended as an AC I-V converter, a job it did very well. DC performance was good, but was supposed to be better.
There was one design, I would have done things differently. It was a 24 channel relay driver. I should have supported the board from the sides of the rack case so the relays could be replaced without major disassembly. I built things as appliances, so they never really got scrapped.
28,113
The only thing that I found a primary to case short on was the very burned power trans of a tube type Monarch brand receiver.It burned because the 2 amp line fuse had been replaced with a 15 amp automotive fuse. The root cause was a plate to cathode hort in an IF amplifier tube. They found a burned up cathode resistor and replaced it with a ten watt one so that it would not burn up again. Just a bit of overload on the B+ line. So then the line fuse would pop, o it was replaced by the 15amp fuse. THEN the power trasformer burned up and the moke convinced them it was all over. Then it came to me. It ended because the new transformer would cost more than the whole receiver.
28,113
Cute display. But a single strip of foil is only good for about 5 amps. (foil from a gum wrapper)
I am not sure about the current, but I saw an accident that burned up a busbar and evaporated a wrench out of a guy's hand. It made a mess of his insulating glove. And he had to change his shorts.
spuddo
Joined May 2, 2013
76
Hi , again thanks for your replies.
The transformer belongs to a Pioneer A-656 reference amp.
As you can see it's built like a brick outhouse , no peeling back paper or tape on this unit to see if the fuse is in order.
I went back to the original wiring------Pin 2 connected to neutral.
Took more readings.
Same result. See attached photos.
240 volts on primary , 0 volts on output.
L on primary (pins 2 & 5) , 18 Henrys.
R on primary ( " ) , 0 Ohms---makes no sense , resolution on the meter is +/- 10 milli Ohms , could it be that the primary
is measured in micro Ohms.
Even took a reading for capacitance-----6.3 nF , getting desperate!
If the transformer is kaput my friend will a have a good boat anchor.
Any thoughts?
28,113
OK, but that meter reading is "open", far from zero ohms. CONNECT THE TWO PROBES TO SEE A ZERO READING.
And the transformer certainly looks like the paper can be opened up to find that internal fuse. Or is that a copper band around the windings? And while the amp does look fairly well made, that fuse buried inside the transformer places a serious doubt about the quality. I have only seen that done in lower quality items, where the transformer quality, or capabilities are marginal. And you would never ever see that in equipment designed to be durable and rugged.
One momentary line voltage spike will pop the fuse and the show is over.
So now it is time to either replace the transformer or remove it and carefully investigate. My money is on that fuse being open.
Now I question the validity of the meter readings , because an open circuit is not likely to have any inductance.
