- Joined Jan 23, 2018
- 28,278
OK!!! That is only a half-day drive (a LONG half-day) !! I used to have couzens near Haymarket, Virginia. One of them still lives on that family farm. A beautiful part of the USA.
A couple weeks or so ago, I ordered a 20 dollar horn speaker to replace a non-working one and installed it. Everything still fine. THEN…couple days ago they called me to ask about that speaker—they are ordering a couple more to add on the ends to help cover the back straightaway section! So…this might be the “straw to break the camel’s back”…Guess I’d better try that testing method you and Panic Mode talked of…I’d hate for them to burn up the powered mixer my wife donated to them…If the end users believe that "It is working fine", then probably it is actually "working good enough" until it isn't "working good enough." So it might be time to pause and "enjoy watching the show."
That really does happen!!
I have had clients who sometimes did not understand that "something was not right", who insisted that all was OK. SOMETIMES, if it is not a disaster warming up for the big explosion, it really can be better to stop and wait. But not if it is a life critical sort of situation.
Hmmm…this amp/mixer is what we typically use for live band shows, so no 70v accommodation…guess we might start looking around for a true PA mixer that is set up with the 70v. I saw one last year at my wife’s little church, as I was helping them figure it all out. (It was already hooked up for ceiling speakers—it was a former funeral home.)Many of the less expensive trumpet speakers are eight ohms impedance. In addition, many of the longer connections are ten to 20 ohms resistance. IF all of the connections are good.
The better connection scheme is to use that 70.7 volt output found on many PA amplifiers, and then select the desired power level on the individual speaker matching transformers.
That "70.7 volt" terminal would be at the 70 volt level with the amplifier delivering it's rated output power. The concept can be a bit confusing until you realize that it takes most of the math out of speaker matching.
Exactly!At a smaller race track itmay be that an actual mixer is not the best choice. But if that is what they already have, and it is working, not needing repairs, it should work for the application.
I recall that the speakers plug into whatever amp you are using, so I am guessing that there is no way to set the amplifier output impedance. I am also guessing that as long as the speech comes thru clearly that is all that matters. Music thru trumpet speakers seldom sounds good, and any effort to increase the bass end can be damaging to the speakers that are intended for clear speech only. Repairing them by replacing the diaphram is rather tedious, and most trumpet speaker brands do not even sell the replacement parts.
REading the specifications sheets for those speakers can be very educational.
I meant "reading the spec sheets" for the newly ordered speakers.Exactly!
As for spec sheets—I’d say it would be a real struggle…many are so aged and weather-ravaged that labels are hard to see, having to climb to reach them, rusted hardware, bees nests, bird nests…I’m not good at standing on a tall ladder and fighting off mad nesters…lol
