Audio Amp
crivoli
Joined May 4, 2006
26
I have built the following circuit but the sound quality is terrible.
Any ideas on how to make the sound quiality MUCH better?
I am using an electret mic and an 8 ohm speaker. Thanks
22,115
You might start by giving us some component values and part numbers. What are we supposed to do, use our extraordinary powers of extra sensory perception to read your fevered brain. Give us a break for pity's sake.
Some questions you might want to ponder.
What is the gain of the amplifier in this configuration?
What do the input and output levels look like?
What is the slew rate of the amplifier?
Is the output being clipped?
n9xv
Joined Jan 18, 2005
329
I think this is the amp in question. I copied & pasted from crivoli's other post under projects. I think parts of the circuit in the above attachment were missing.
22,115
[post=17021]Quoted post[/post]​
Well OK, looks like the gain of the amplifier is 20 to 30 dB.
He replaced the vlume control with a fixed resistor.
What did he do with the other amp in the package? I'll bet he left the inputs wide open. A bypass cap on the Vcc pin couldn't hurt.
crivoli
Joined May 4, 2006
26
I am using
1K resistors for Rb,
a 1M resistor for R2,
a 1K resistor for R1,
a 10uF cap as already seen,
a .47uF cap for the coupling cap from the mic to the IC,
a LM741 IC and a 68uF cap out of the IC to the speaker....
Sorry for not posting the specs
kubeek
Joined Sep 20, 2005
5,796
Originally posted by crivoli@May 12 2006, 11:58 AM
I am using
[post=17023]Quoted post[/post]​
gain as high as 1000 is way too much, use something more reasonable, like 20-200, which leads the R2 to 20k-200k.
What is the amplitude of the input signal?
If the input is the microphone like in the previous topic, than MAYBE the gain of 1000 is apropriate.
What amount of power are you planning to get on the output? If you would look at the schematic, then you would see it is PREamplifier. It is not capable of driving an 8-ohm speaker. You should try either a speaker with higher impedance like 200ohm or more, or use some other amp like the good-old LM386, which can handle up to 1W into 8-ohm load, and is perfectly suitable for electret-mike amp.
hgmjr
Joined Jan 28, 2005
9,027
Originally posted by crivoli@May 12 2006, 04:58 AM
I am using
I suspect that the LM741 is unable to drive the speaker being used. The amplifier you have constructed constitutes an audio pre-amp. Now what you need is a buffer stage capable of driving the speaker.
You may be able to get by with a push-pull transistor amp as shown in the link below. This push pulls stage would need to be incorporated into the feed back loop of the stage you already have. This is necessary to prevent the push-pull stage from introducing excessive cross-over distortion.
Push Pull amp stage
hgmjr
crivoli
Joined May 4, 2006
26
Push Pull amp stage
hgmjr
[post=17025]Quoted post[/post]​
I switched over to a LM386 design from the datasheet and it works like a charm.
I appreciate everyone's advice VERY MUCH!!
Thanks again
hgmjr
Joined Jan 28, 2005
9,027
Thanks again
[post=17038]Quoted post[/post]​
That is great news. Congratulations!
hgmjr
