Attenuator calculation or formula
PickyBiker
Joined Aug 18, 2015
101
I have a microprocessor that is putting out 3.4V pulses and it needs to drive a sensor with a max input voltage of 2.4V
I think a T attenuator would work, but I don't know to calculate the values. Anyone got a calculator that works with voltage instead of db? A simple formula would be alright too.
17,498
There are more than one way to do this, but I might just use a resistive divider. What does the sensor require in terms of current, mA?
Another way could be as simple as putting 2 diodes in series with the signal. Together they will drop ~1.2-1.4V.
17,498
The current required to raise/lower the sensor input is 10ua.
In that case, a resistive divider as I and #12 mentioned, and which #12 illustrated, would be fine. The 10µA load of the sensor would introduce only a small error (~1% max) in the 1mA flowing through the resistors. That error is likely dwarfed by other sources of experimental error.
